Home » Sponsored » Pi Speakers » Studio .5 pi idea
Studio .5 pi idea [message #49526] Thu, 25 May 2006 10:50 Go to next message
sdoow is currently offline  sdoow
Wayne,
I have been toying with the idea of building some speakers for HT. For the surrounds, BR box tuned to 80-100hz w/Alpha6 and DX25. The speakers need to fit on shelves 11.5h x 14.5d x 19w. Sub, as yet undecided, so many possibilities.
I had been contemplating the Studio One Pi, which would fit, but I want to keep the tweeter above the woofer, thus the desire to try a 6" woofer.
Any thoughts?
Sincerely,
Greg
Re: Studio .5 pi idea [message #49527 is a reply to message #49526] Thu, 25 May 2006 13:05 Go to previous messageGo to next message
I think it will probably work out very nice but no bass. Even the Alpha 8 is a little lacking without boundary loading and/or cabin gain. But with a sub, your six-incher could sound very good. If you just don't need anything below 100-150Hz or so, you'll probably have a very nice sounding speaker above that.
Re: Studio .5 pi idea [message #49528 is a reply to message #49527] Thu, 25 May 2006 15:09 Go to previous messageGo to next message
Thanks Wayne,
I figure I'll play around with PiAlign, BoxPlot, WinISD, and maybe some other programs before settling on final tuning. Since I will be using them for 5.1 HT duty I think 100-150hz should work reasonably well. Obviously the lower I can go the more seamless the transition to the sub will be. I plan on following your lead regarding the X-over, allowing the Alpha6 to roll off at around 4K.
Greg
Re: Studio .5 pi idea [message #49529 is a reply to message #49528] Thu, 25 May 2006 17:30 Go to previous messageGo to next message
Look at some of the A/V Foxtex drivers. I've used several is a Pi
sort of arrangement and have been very happy with them.
Try: FE-127's, FE-167's, etc.
Chris
Re: Studio .5 pi idea [message #49531 is a reply to message #49529] Fri, 26 May 2006 10:04 Go to previous messageGo to next message
Thanks Chris,
Thankfully, I have an RPTV so shielding is not neccessary.
I have several RS 40-1197/FE103's, and have been generally pleased with them in folded TQWP's. They are somewhat less satisfying in a BR, sounding a bit thin to my ear.
The advantage that I see of trying a sort of .5 Pi, at least compared to what I have, is better off axis response with the DX25, slightly higher overall efficiency, and greater dynamics with the Alpha6.
I just want to make sure that I am not completely off track with my thinking before I plunk down any cash.
Greg
Re: Studio .5 pi idea [message #49533 is a reply to message #49526] Fri, 26 May 2006 17:30 Go to previous message
Have a look at the Eminence LA6-MB. It's kind of a of beefed-up Alpha-6 and can take you down below 100Hz on a vented box.
Previous Topic: Skip Pack -question on coil for Two Towers.
Next Topic: 8pi port ?
Current Time: Wed Oct 07 09:43:53 CDT 2026
