Home » Sponsored » Pi Speakers » Wayne, sub plans?
Wayne, sub plans? [message #49489] Fri, 19 May 2006 09:52 Go to next message
Wayne, do you have any drawings and/or speaker recommendations for a small sub that I could put a plate amp on? Was thinking of getting the small drivers Akhilesh had at GPAF, but will definitely need a sub for them. I'm thinking inexpensive set here since the little full rangers are so cheap.
Re: Wayne, sub plans? [message #49490 is a reply to message #49489] Fri, 19 May 2006 13:36 Go to previous messageGo to next message
Yeah, I have a couple of reasonably small subs that would be great for what you're looking for. I'll send plans if you're interested.
Re: Wayne, sub plans? [message #49493 is a reply to message #49490] Fri, 19 May 2006 15:01 Go to previous messageGo to next message
Please do.
You've got mail! [message #49496 is a reply to message #49493] Sat, 20 May 2006 10:37 Go to previous messageGo to next message
Amp question! [message #49498 is a reply to message #49496] Sat, 20 May 2006 18:34 Go to previous messageGo to next message
Wayne, what size plate amp would you recommend as a minimum with the designs you sent?
Re: Amp answer [message #49499 is a reply to message #49498] Sat, 20 May 2006 23:22 Go to previous messageGo to next message
A 100 watt amp would do just fine, but you might also consider a 250 watt or 500 watt amp. The three π sub will handle 400 watts and the four π-18 sub will handle 800 watts.
Re: Wayne, sub plans? [message #49515 is a reply to message #49489] Fri, 19 May 2006 13:36 Go to previous messageGo to next message
Re: Wayne, sub plans? [message #49517 is a reply to message #49490] Mon, 22 May 2006 14:43 Go to previous messageGo to next message
John Van is currently offline  John Van
I would be interested in these sub plans as well. Thanks.
You've got mail! [message #49518 is a reply to message #49517] Tue, 23 May 2006 00:05 Go to previous message
Previous Topic: High End Stuff II..THIS sounds like the real deal!
Next Topic: theater 4pi boxes- free
Current Time: Sun Oct 25 03:19:18 CDT 2026
