Home » Sponsored » Pi Speakers » Corner Horn positioning "Sweet Spot" for listening...HELP
Re: Corner horns without the triangular baffle [message #49429 is a reply to message #49428] Wed, 03 May 2006 05:05 Go to previous messageGo to previous message
Tobias is currently offline  Tobias
My 7Pi have the triangular extensions top and bottom per plan. I just never got around to adding the 'dog house roof' rear panels. I have the panels cut and finished, and ready to install. I myself am not sure what value they would add other then additional support. Even then the bottom plate is made up from doubled up 3/4 plywood, and I have cherry trim on top which makes the top plate more rigid then normal. The midhorn needs the extra depth for support.
Previous Topic: Cornerhorns for this room?
Next Topic: 2 pi and PiAlign program
Current Time: Mon Oct 05 08:59:07 CDT 2026
