Home » Sponsored » Pi Speakers » lascala cabinets
lascala cabinets [message #49348] Wed, 19 April 2006 23:41 Go to next message
rian is currently offline  rian
i've got a pair of klipsch lascala cabinets. no drivers or x-overs. does pi have something i could plug in w/o breaking the bank?
thanks!
Re: lascala cabinets [message #49352 is a reply to message #49348] Thu, 20 April 2006 10:11 Go to previous messageGo to next message
The replacement drivers for LaScalas are cheap, so just replace them with the factory replacement parts.
Re: lascala cabinets [message #49354 is a reply to message #49352] Thu, 20 April 2006 18:21 Go to previous messageGo to next message
I am searching for a bookmark I used to have , possibly from the klipsch site? where in the deal was to install a JBL woofer and then vent it. They seemed to think it was the bomb.
russellc
Re: lascala cabinets [message #49355 is a reply to message #49354] Thu, 20 April 2006 22:31 Go to previous messageGo to next message
Seems like they used the JBL 2205. I've heard of some doing a similar thing with Klipschorns, but without the vent.
Re: lascala cabinets [message #49359 is a reply to message #49355] Fri, 21 April 2006 19:19 Go to previous messageGo to next message
Yes it was the 2205 I read about, it was vented but I do not remember where, seems like it was a little lower, 35 hz maybe? I remember some slight adjustments to the cross over for the different driver, but I really dont remember what or how! I am sure someone on the klipsch forum can give the particulars. I have also read, I believe in the same article, as well as others, that they recommended a slightly different klipsch woofer also for netter bass in the stock arraingement than the original woofer provided. The klipsch drivers are reasonable in price, all things considered. Most I have seen, while they do the job, were light weight stamped frame and in stark contrast to the cast monsters made by altec and jbl. dont misunderstand, I have no problem with klipsch, just an observation about driver construction.
russellc
Re: lascala cabinets [message #49362 is a reply to message #49359] Mon, 24 April 2006 15:22 Go to previous messageGo to next message
Klipsch drivers are OEM made Emimence drivers for Klipsch. That's why the construction different from EV, JBL, Altec etc..
Bill W.
Re: lascala cabinets [message #49367 is a reply to message #49354] Tue, 25 April 2006 04:16 Go to previous messageGo to next message
Frode is currently offline  Frode
I used the 2226H in a vented LaScala cabinet. There are several threads about this on the Klipsch forum:
http://forums.klipsch.com/forums/thread/703467.aspx
http://forums.klipsch.com/forums/thread/329570.aspx
http://forums.klipsch.com/forums/thread/253878.aspx
http://forums.klipsch.com/forums/thread/345616.aspx
http://forums.klipsch.com/forums/thread/259799.aspx
Frode
Re: lascala cabinets [message #49370 is a reply to message #49362] Tue, 25 April 2006 12:58 Go to previous messageGo to next message
Mainly I am refering to construction quality, the JBL and Altec are big heavy cast frames, whereas the klipsch drivers I have seen are stamped, much lighter weight items. Apparently, they do the job fine, just noting construction differences is all!
Russellc
Re: lascala cabinets [message #49371 is a reply to message #49367] Tue, 25 April 2006 13:02 Go to previous messageGo to next message
Thankyou, I new one of the Klipsch guys could show us this, Thanks again. I have wanted a Lascala project since the 70s, but only so many large horn speakers can reside in my small house at the time.
Russellc
Re: lascala cabinets [message #49380 is a reply to message #49371] Wed, 26 April 2006 13:44 Go to previous messageGo to previous message
Well, it's nice to be able to help, but I wouldn't describe myself as one of the Klipsch guys. I built some La Scala bass bins to fill inn below my Oris horns. Nowadays I use the original Oris bass system. As you say, horns occupies a lot of space.
Frode
Previous Topic: Attenuation for Theatre-3
Next Topic: Wave Guides?
Current Time: Wed Oct 21 01:43:11 CDT 2026
