Home » Sponsored » Pi Speakers » Wood hf horn.
Wood hf horn. [message #49299] Tue, 11 April 2006 04:21 Go to next message
Paul Holland is currently offline  Paul Holland
Are there plans available for wood hf horns?
If so, could you send them to me to suit pi 8
Cheers,
Paul,
Aus.
Re: Wood hf horn. [message #49300 is a reply to message #49299] Tue, 11 April 2006 07:33 Go to previous messageGo to next message
We're hoping to have the tweeters ready for production in the next couple of months but no drawing or assembly plans are available. They will only be available as finished ready-to-use tweeter horns.
Re: Wood hf horn. [message #49307 is a reply to message #49300] Wed, 12 April 2006 05:32 Go to previous messageGo to next message
Back in mid November 2005 you emailed out wood hf plans to several forum participants who requested them.
I am concerned about freight costs to Australia for built up items.
Paul.
You've got mail! [message #49310 is a reply to message #49307] Wed, 12 April 2006 10:31 Go to previous messageGo to next message
You're right, I do have plans packaged for distribution. I must be getting old, sorry.
Re: You've got mail! [message #49313 is a reply to message #49310] Wed, 12 April 2006 14:29 Go to previous messageGo to next message
dB is currently offline  dB
Hi,
Never mind Wayne, your posts are the Best (Speaker Posts of the Web). Keep it going. My congratulations for your work, and thanks. Your work is a Work of Art. As I said before, I don't know if I would buy a tweeter horn from you or if I would build one and learn from it. It's a difficult win-win decision. Good luck for your next convention/expo or show at Great Plains Audiofest - May 5, 6 and 7, 2006
Tulsa, Oklahoma. It must be great. I have been there for a few Wine Festivals in Maryland.
Regards
Re: Wood hf horn. [message #49316 is a reply to message #49300] Thu, 13 April 2006 19:54 Go to previous messageGo to next message
Wayne, how will they differ from the wood tweeter horns you now offer on the Pi speakers web site? Appearance? Price? Performance?
Re: Wood hf horn. [message #49317 is a reply to message #49316] Thu, 13 April 2006 21:30 Go to previous messageGo to next message
Wood horns that I've sold in the past were made by Bill Martinelli. They're a pretty good horn, but the sides are curved and the top and bottom are straight. The expansion is fine but I don't like that profile. The new horns have straight side walls and the top and bottom flares are curved to create the area expansion and to open much wider and reduce diffraction.
Re: Wood hf horn. [message #49318 is a reply to message #49317] Fri, 14 April 2006 10:38 Go to previous messageGo to next message
Hi,
After paying attention (and learning from it) to some of the work done by Wayne (and others) I found a very interesting Patent (#4,469,921) from Kinoshita, 1984, with a "similar" horn design.
<<Sectoral horn with side walls linear and opening degree or angle of the horn adjusted by the upper and lower curved walls>>
The interest of this is that it explains how a type ""shelf"" frequency response of the horn becomes flat and directivity is improved in the necessary frequency band. With a two angle throat for different frequencies.
Nice.
Re: Another horn. [message #49322 is a reply to message #49317] Sat, 15 April 2006 07:46 Go to previous messageGo to next message
Hi, Wayne (and PiSpeakers Forum)
I just found this paper from Peavey. You must have read it already.
Is good for learning and also developing diy horns.
Best Regards
Re: Another horn. [message #49324 is a reply to message #49322] Sat, 15 April 2006 09:39 Go to previous messageGo to previous message
Yes, we've discussed this horn a lot over the years. I think its a great way to shape the flare, particularly the driver/throat transition.
Previous Topic: Oh MY
Next Topic: Tell us about YOUR insecurities
Current Time: Sat Nov 28 17:24:40 CST 2026
