Home » Sponsored » Pi Speakers » JBL 2426/2370 cd compensation and crossover point
JBL 2426/2370 cd compensation and crossover point [message #49234] Sat, 01 April 2006 12:44 Go to next message
ccvogel is currently offline  ccvogel
The frequency response curve [see image URL] published by JBL for the 2426/2370 does not seem to exhibit the 6 dB/octave decline that has been described in other posts as typical of CDs. Is CD compensation required for this combo?
Also, what range of crossover frequencies works best with the 2426/2370 when crossed over to a JBL 2226 in a 3.0 cu ft cabinet tuned to 40 Hz? I'm thinking that the 1600 Hz point in the Four-pi might be an accommodation for the H290 Horn???
Thanks,
ccvogel
Re: JBL 2426/2370 cd compensation and crossover point [message #49253 is a reply to message #49234] Mon, 03 April 2006 10:10 Go to previous messageGo to next message
Measure the 2426/2370 combo and see what you come up with.
Will do; thanks [message #49254 is a reply to message #49253] Mon, 03 April 2006 14:00 Go to previous message
Previous Topic: Top port?
Next Topic: speaker recommendation
Current Time: Fri Nov 13 06:53:57 CST 2026
