Home » Sponsored » Pi Speakers » Stage 4Pi improvement
| Re: Stage 4Pi improvement [message #49025 is a reply to message #49007] |
Mon, 06 March 2006 08:54   |
GarMan
Messages: 960 Registered: May 2009
Illuminati (2nd Degree) |
Hey LAL. Thanks for the report. I noticed that your cabinets were lined live-side/dead-side with fibreglass, but pretty much all around with Sonic Barrier. No doubt, the resulting improvements were probbably a combination of different material and placement. I'd be interested in knowing how much of it was gained with material vs placement (ie. would you get the same results if five sides were lined with fibreglass). Unfortunately, it sounds like it's impossible for you to remove the Sonic Barrier to test. Also, was there a reason why "Glop" was originally only used on the unlined sides? Fibreglass does a good job of absorbing soundwaves but not much to dampen panels. I've found that putting some type of Glop-like material on all internal walls before lining with absorbant works very well to reduce boom. Gar.
By: LAL on Sat, 04 March 2006 10:39
By: Pfenning on Sat, 04 March 2006 11:10
By: LAL on Sat, 04 March 2006 14:18
By: Matts on Sat, 04 March 2006 21:50
By: LAL on Sun, 05 March 2006 10:23
Re: No offense, Matts, but
By: Matts on Sun, 05 March 2006 13:06
By: LAL on Sun, 05 March 2006 19:44
By: Matts on Sun, 05 March 2006 21:02
By: LAL on Sun, 05 March 2006 21:22
** TRUE SONICS **
Earplugs
By: dB on Tue, 07 March 2006 05:43
Re: First order x-over
By: dB on Wed, 08 March 2006 07:37
By: Matts on Sun, 05 March 2006 21:06
By: GarMan on Mon, 06 March 2006 08:54
By: ToFo on Mon, 06 March 2006 13:17
By: LAL on Tue, 07 March 2006 14:32
By: GarMan on Wed, 08 March 2006 07:30
Understandable Results
By: FredT on Mon, 06 March 2006 13:35
Current Time: Thu Nov 05 21:40:00 CST 2026
