Home » Sponsored » Pi Speakers » Fountek Ribbon Tweeter
Fountek Ribbon Tweeter [message #48960] Thu, 23 February 2006 13:06 Go to previous message
dB is currently offline  dB
Hi,
I need to model a FOUNTEK NeoCd2.0 Ribbon Tweeter in Spice.
Are the parameters I am using ok?
R=6.5Ohms (for Re)
L=0.1mH (for Le)
(1)The problem is that they don't publish the Le parameter.
(2)Also the impedance is 7 Ohms (nominal) but in the graphics curve of response & impedance it shows impedance coming down to 6.75 Ohms @2kHz and 6.5Ohms @3kHz. Which impedance is the best choice to model in Spice, with x-over at 2kHz?
(3)What is this ---> DCR 0.02 ohm, from the factory .pdf catalog?
(4)I am not using compensation for HF, what do you think?
Website here(http://www.fountek.net/products_neo_20.htm);
or here(http://www.madisound.com/neocd2.0.html).
Thanks Wayne.
Best Regards
Previous Topic: deltalf
Next Topic: Re: Seven pi-18 photos?
Current Time: Sat Oct 17 22:09:19 CDT 2026
