Home » Sponsored » Pi Speakers » Two Pi Towers complete
Two Pi Towers complete [message #48946] Wed, 22 February 2006 08:15 Go to next message
ozzi is currently offline  ozzi
Finally after having the completed shell and intestines in storage for over two years, I finally decided to complete my two Pi towers.
Initially I wanted them as front speakers together with three one Pis for a Home theatre system, but I was discouraged at what my HT amplifier delivered. I will use them therefore for stereo only.
The reason that I had them away for so long was that I really wanted to have them veneered, but I eventually changed my mind and had them painted. After completing them, I hooked them into my Denon Amp and man what a sweet sound. I'm impressed Solid Bass, clear mids and crisp highs, the piezos sound just fine. I,m sure they will sound even better when I change the amplifier for a better one.
I haven't heard of any other builders of PiSpeakers in South Africa, if there are any near me, I will be glad to hear from them. I am in Pretoria.
I tried to put pictures on the web and I hope you can access the URL below. I painted them with one coat wood primer, one coat universal undercoat and three coates of Plascon suede, a translucent type paint that gives a 3d effect. I applied the finishing coat with a hard brush to give it a slight wood grain effect. I will try to varnish it by this week end.
The one pis are incomplete as I cannot find 60mm cardboard tube anywhere. If I don't, I will settle for plastic.
Thanks for all your help over the years Wayne.
Oscar
http://www.kodakgallery.eu.com/BrowsePhotos.jsp?&localeid=en_GB_EURO&collid=62406527933
Re: Two Pi Towers complete [message #48947 is a reply to message #48946] Wed, 22 February 2006 09:06 Go to previous messageGo to next message
That's super, Oscar! Thanks for posting. If you still can't find the port tube, let me know and I'll mail one to you.
Re: Two Pi Towers complete [message #48953 is a reply to message #48947] Wed, 22 February 2006 23:37 Go to previous messageGo to next message
Thanks Wayne
To be honest, I have not looked that hard. My ideal ports would have been the ones you buy at the electronics shop. What I really need though is logos for all 5 speakers, but I'm not in a hurry. I may be ordering some crossover networks from you in the future, maybe then I will ask for evrything else I need.
Cheers
Oscar
Re: Two Pi Towers complete [message #48958 is a reply to message #48953] Thu, 23 February 2006 08:30 Go to previous message
Let me know your address, I'll slip some logos in the mail.
Previous Topic: One Pi
Next Topic: deltalf
Current Time: Fri Nov 06 06:15:16 CST 2026
