Eminence ASD 1001 [message #48792 is a reply to message #48790] |
Fri, 03 February 2006 14:22 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
FredT
Messages: 704 Registered: May 2009
Illuminati (1st Degree) |
I hesitate to comment since I have never heard it, but its frequency response curve reminds me of the $30 Selenium DH200E, which I once compared directly to the Eminence PSD 2002 sitting atop the 3 Pi's. Using the standard 3 Pi crossover I found the treble response dropped very sharply with increasing frequency, so much so that it sounded like there was no "presence" with the Selenium. I notice the Eminence 1001 has the same kind of drop between 3.5 and 10khz. The 2002 is a bit pricey in comparison (all good compression drivers are), but it carries all the information above 1,500khz in the 3 Pi, and I would be concerned it might not sound very good. Compare the freq response graphs on the mfg spec sheets for the 1001 and the 2002. The 2002 has a dip too, but the capacitor that parallels the series resistor in the L pad does a reasonably good job of compensating. I doubt it would for the 1001.
Re: Final Picture [message #48839 is a reply to message #48808] |
Tue, 14 February 2006 05:19 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) |
Bill Epstein
Messages: 1088 Registered: May 2009 Location: Smoky Mts. USA
Illuminati (2nd Degree) |
Just saw this post; nice job on the baffle. You have a much steadier hand with the sabre saw. I had the Vifa up at 12000 and it "wasn't there" like you suggest, but didn't add anything to the extension of the 902's so I brought it way down. If anything, the Vifa is now the main tweeter above 6000 and the 902's the augmentation. One-of-these-days I'll get some ribbons and try your way.
