Home » Sponsored » Pi Speakers » two questions Wayne.
two questions Wayne. [message #48706] Thu, 26 January 2006 15:33 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy.Wayne where work better a speaker port , In the front of the cabinet radiating free to the room or in the back of the speaker a couple inches from the wall . Second question according the eminence website the Alpha 10 have a spl between 500hz and 3500 hz of 94-95 db my question is How much decibels of gain have the alpha 10 when put in a mid-horn enclosure driven by 2.83volts .thanks
Re: two questions Wayne. [message #48707 is a reply to message #48706] Thu, 26 January 2006 20:22 Go to previous message
The Alpha 10 on the midhorn generates 105dB/W/M.
For vented cabinets, port position won't matter unless airflow is restricted. So if the port is small and/or displacement of the driver is high, vent airspeed may cause turbulence from a nearly spaced wall. It's probably a good idea to keep a distance of at least port diameter or so from any obstruction.
Another thing to consider is standing wave nodes. If all dimensions of the box are small compared to the wavelengths presented to it, then standing waves won't form. But if a box dimension becomes acoustically large - 1/4λ or greater - then standing waves will form inside. Port and driver position are important in a box like this. Once the box is large enough in any dimension, it develops pipe modes and if you put the port or driver in a standing wave node, you'll see ripples in response as a result.
Previous Topic: 2 Pi Towers with PSD2002 crossed over at 1.6Khz
Next Topic: 7pi vs. JBL Hartsfield
Current Time: Sun Oct 25 03:23:01 CDT 2026
