Home » Sponsored » Pi Speakers » Check out this woofer
Check out this woofer [message #48649] Sat, 21 January 2006 18:47 Go to next message
95dB, 29 Fs, $230 bucks
Re: Check out this woofer [message #48650 is a reply to message #48649] Sat, 21 January 2006 23:01 Go to previous messageGo to next message
Cool!
We used to use the Peavey Black Widow 1202-4 and the 1801-8's in our setup when we were playing gig's. They are both good sounding speakers, but the FS is better on the Usher. The 1202-4's are made to be used in horns.
Re: Check out this woofer [message #48653 is a reply to message #48649] Sun, 22 January 2006 19:14 Go to previous messageGo to next message
Yes!
I was looking at these too. Looks like they would make a solid mid sized two-way without the need for a sub(4.5 cubic feet). Since you're not afraid of big boxes check the Usher 15PA. Simulate it in 6.8 cubic feet @ 32Hz and hang on to your grin muscles.
Thomas
Re: Check out this woofer [message #48655 is a reply to message #48649] Sun, 22 January 2006 21:43 Go to previous messageGo to next message
If you get one of 'em, let us know how it sounds.
Re: Check out this woofer [message #48670 is a reply to message #48653] Mon, 23 January 2006 18:41 Go to previous messageGo to next message
It appears to my untrained eye that the HM has less trouble reaching for 1500 Hz. If so, maybe giving up a little low end grunt and getting a smaller box would be worth it.
Re: Check out this woofer [message #48686 is a reply to message #48670] Tue, 24 January 2006 21:37 Go to previous messageGo to next message
I hope I am looking at the same graphs (296-630.pdf & 296-632.pdf respectively). They looked like the same driver to me at first. This is bugging me now. Anyway, I must confess that I wasn't paying attention above 1K (BIG HF horn & deeper driver coming soon). They both looked great to me.
As for the bass; on further inspection the 15PA is only +2 or 3dB from 30 to 40, which is not exactly huge. They can both be tuned to play solid to 30-something in most domestic sized rooms, & that is pretty cool. It seems we both like the other driver for the same reason, box size. I like the sound of a big cabinet. I do not know why, but box size seems to be a big deal in my room. That and a bit more in the mid thirties will put me over the edge when I take my musical taste into account.
Re: Quite right [message #48687 is a reply to message #48686] Wed, 25 January 2006 05:32 Go to previous messageGo to next message
W/O being able to overlay the 2 graphs it's really hard to tell the difference.
I'm also looking at the B&C woofers Earl Geddes uses. Look how close the specs track the 2226.
There's so much more available to us today than just JBL and Eminence. Cool!
Re: Check out this woofer [message #48780 is a reply to message #48649] Thu, 02 February 2006 14:49 Go to previous messageGo to next message
Anonymous
If you like that type of driver, then you should look into this
one. The new person who makes them I believe can make those for
a lower price than the usher if you buy a pair ... and I'd bet my
paycheck the Usher would get beat pretty bad by it.
http://home.pacbell.net/lordpk/lambda/TD15M.html
email for details if you want to know the skinny.
Re: Check out this woofer [message #48783 is a reply to message #48780] Thu, 02 February 2006 15:05 Go to previous message
Anonymous
Link;
http://www.aespeakers.com/phpbb2/viewtopic.php?t=359
Previous Topic: Midrange cabinet
Next Topic: SPICE parameters
Current Time: Fri Nov 13 05:18:49 CST 2026
