Home » Audio » General » Slide show
Slide show [message #4861] Sat, 10 May 2008 21:02 Go to next message
Wayne,
I'd like to post my slides. How and where would you like them downloaded. The slides are presently in Power Point 2007 format, but that can be changed.
Bob
Re: Slide show [message #4862 is a reply to message #4861] Sat, 10 May 2008 23:33 Go to previous messageGo to next message
E-Mail them and I'll put them on ART, with a link to the presentation right next to your audio file.
Re: Slide show [message #4863 is a reply to message #4861] Sun, 11 May 2008 08:16 Go to previous messageGo to next message
Martin is currently offline  Martin
Bob and Wayne,
Older versions of Powerpoint, the 2003 version I use with XP, cannot open the file. Could you save is as an earlier version or perhaps a pdf file?
Martin
Re: Slide show [message #4864 is a reply to message #4863] Sun, 11 May 2008 10:51 Go to previous messageGo to next message
Let me look at that. Back soon
Bob
Re: Slide show [message #4865 is a reply to message #4864] Sun, 11 May 2008 11:29 Go to previous messageGo to next message
I send Wayne a collection of GIF files. That seems to be the only sure way to make them available. If I get a chance in the next day or two, I'll collect them into a PDF file. That should work also, but will take a while to put together.
Bob
Re: Slide show [message #4866 is a reply to message #4865] Sun, 11 May 2008 11:45 Go to previous messageGo to next message
Can PowerPoint 2007 save in 2003 format? If it can, then if you send me the file I can write it out into pdf format. I have done that before and it works very well with my Acrobat writer.
Re: Slide show [message #4867 is a reply to message #4866] Sun, 11 May 2008 12:12 Go to previous messageGo to next message
Martin,
I can do the PDF file myself. I just need to take a while to get it done. I'll do it tonight and send it to Wayne.
Bob
Re: Slide show [message #4869 is a reply to message #4867] Mon, 12 May 2008 23:18 Go to previous messageGo to next message
The PDF file is in place. Thanks for doing the presentation!
Re: Slide show [message #4870 is a reply to message #4869] Tue, 13 May 2008 08:19 Go to previous message
Thanks Bob and Wayne.
Martin
Previous Topic: 5 days and counting!!!
Next Topic: White Lightning ICs
Current Time: Fri Nov 27 06:03:06 CST 2026
