Home » Sponsored » Pi Speakers » JBL 2225H for 7pi
JBL 2225H for 7pi [message #48525] Wed, 04 January 2006 21:28 Go to next message
Kim Schultz is currently offline  Kim Schultz
Hi.
Can I use the JBL2225H in the 7pi ?
I can buy 4 of them used for about $560, is this a good price or should I try to get a better price ?
Re: JBL 2225H for 7pi [message #48526 is a reply to message #48525] Thu, 05 January 2006 04:48 Go to previous messageGo to next message
spkrman57
For JBL's own systems, the 2226 is the modern version of the 2225 and considered a drop-in replacement.
I would say the differences would be subtle at most!
Ron
Re: JBL 2225H for 7pi [message #48528 is a reply to message #48525] Thu, 05 January 2006 08:41 Go to previous messageGo to next message
Yes, you can substitute the JBL 2225 for the 2226 in the seven π loudspeaker.
Re: JBL 2225H for 7pi [message #48562 is a reply to message #48528] Mon, 09 January 2006 04:03 Go to previous messageGo to next message
Hi Wayne.
Ended up buying 6 working 2225H and one where the voicecoil is burned for $650.
Should I leave the port the same as in the Audiophile Pi7 ?
When doing simulations of the Eminence Magnum15HO and the JBL2225H in JBL Speakershop, they model very close.
I use 65 litre with 140cm2 x 38cm long port, is this correct ?
Re: JBL 2225H for 7pi [message #48564 is a reply to message #48562] Mon, 09 January 2006 08:54 Go to previous message
The cabinet for the Audiophile series seven π will work just fine with a JBL 2225. No changes necessary.
Previous Topic: 500 Hz mid-horn search
Next Topic: tower pic
Current Time: Sun Nov 01 10:22:59 CST 2026
