Home » Sponsored » Pi Speakers » Cross Over Question
Cross Over Question [message #48551] Sat, 07 January 2006 16:12 Go to next message
HaknHendrix is currently offline  HaknHendrix
Here goes...
Situation:
I picked up a pair of JBL 2446J (160hm) compression drives with horns.
Current Configuration:
I have 4 Pi Towers (LaPaier's, 6.5 cubic ft), loaded with Eminence 15" Delta Pros and PSD2002 and an Eminence/PI 2-way 1.6KHz crossover. The 4 Pi's sound excellent!
Picked up the 2446J's because I'm infected with the audio diy virus.
Short Term Goal:
What crossover modifications would I have to make to simply connect the JBL 2446J in place of the PSD2002s. Would I to hear and compare.
Mid Term Goal:
Build a crossover - crossed over at perhaps 500Hz - 800Hz? This would be a better frequency for the JBL 2446J.
Please advise, or suggest a more rational approach.
thanks
Jim
Re: Cross Over Question [message #48552 is a reply to message #48551] Sat, 07 January 2006 21:35 Go to previous message
There are 500Hz, 800Hz, 1kHz, 1.2kHz and 1.6kHz two-way crossovers with top-octave compensation on the π crossover schematic document and also in the Spice distribution. You might check them out and see which one you liked best. I think you'll find at least one of them will work very well for you.
Previous Topic: new studio two towers
Next Topic: 500 Hz mid-horn search
Current Time: Sun Nov 01 14:24:50 CST 2026
