Home » Sponsored » Pi Speakers » Pre Compensation Load on X-OVERS and L-Pads
Re: Pre Compensation Load on X-OVERS and L-Pads [message #48539 is a reply to message #48516] Fri, 06 January 2006 04:50 Go to previous messageGo to previous message
dB is currently offline  dB
Hi and thank you very much to take from your time to answer my questions.
First, I would like to ask you what are the advantages of using the compensation circuit on the “right side” of R2 instead of the ones on the left side like the L-Pads from lalena.com and others. They seem to deliver less wattage to the speaker trough the process and to “burn more energy to the air”, if I have my two pages of numbers right and not taking in consideration reactances from the capacitor for the break frequency and the one´s from the main circuit.
Example
LPad – Driver Attenuation Circuit for –2.4 dB
R1=1.93 Ohm, R2=25.14 Ohm, Speaker=8 Ohm
For a Total of 300Watts: R1=72.4 Watt, R2=172.7 W, Speaker-54.9 W
With and after compensation on R1: R2=227.6 W, Speaker-72.4 W
With your Compensation+precompensation Circuit for –2.4 dB
R1=2.5 Ohm, R2=34 Ohm, Speaker=8 Ohm (Attenuators from page 23 of your Paper)
For a Total of 300Watts: R1=16.8 Watt, R2=229.2 W, Speaker-54 W
With and after compensation on R1: R2=243 W, Speaker-57 W
I just happened to find a site to - Calculate the resonant frequency of a capacitor and inductor - http://www.mhsoft.nl/Mysystem/Reactance.asp - that I was asking for in my first question to you. Do you think this is good/right for Hi-Fi filter calculation. Does a resistor, like the one’s on attenuations, change this (the resonant frequency) or not? I am learning on how to work w/ SPICE. Is there a website for Speaker File Spice Databases? Thanks again.
Best Regards
da Bastos
Previous Topic: 7pi
Next Topic: Pro Pi4 plans please.
Current Time: Sun Nov 01 15:53:51 CST 2026
