Home » Sponsored » Pi Speakers » progress pi4
progress pi4 [message #48314] Sun, 27 November 2005 05:42 Go to next message
roland is currently offline  roland
Hi there,
I seem to progress, but still the custom port (many layers of mdf routed and glued) to be made, but cabs are oiled and looking good:). Why? cause I chose a weird shape of the port. I did keep the area the same though.
Now it's time to let dry, surfaces soaked. Patiance I guess i a good thing.
Roland
Re: progress pi4 [message #48315 is a reply to message #48314] Sun, 27 November 2005 08:51 Go to previous messageGo to next message
That speaker looks great! Looks like it won't be long now and you'll be making music!
Re: progress pi4 [message #48316 is a reply to message #48314] Mon, 28 November 2005 07:51 Go to previous messageGo to next message
I like the flush-mounting for the horns. Gives a very finished look. Did you do that free-hand or with a router and template guides?
Re: progress pi4 [message #48320 is a reply to message #48316] Mon, 28 November 2005 12:22 Go to previous message
Thanks, it does give the whole louspeaker a less DIY and more professional look. As per some advice here I went for it as I didn't want to forke out all that effort/time and money for an obviously home-made speaker. Now it's more subtle....
me freehand?? LOL:) I followed the instructions as per a very helpfull poster here...you!!? With one succesfull run to create the first template you are home free. I then used the same template approach for the port....it has the same dimension height-wise as the horn cut-out.
Roland
Previous Topic: plans for studio towers
Next Topic: 8pi port ?
Current Time: Mon Nov 02 02:02:50 CST 2026
