Home » Sponsored » Pi Speakers » Wayne, cab question...
Wayne, cab question... [message #48317] Mon, 28 November 2005 08:35 Go to previous message
one_speed is currently offline  one_speed
A while back, I posted regarding the Fostex FW305, and you were kind enough to make some suggestions. As a quick reminder, my plan is to cross at 200hz. to a full range driver.
You recommended going up to a 4 cu. ft. cab and gave thoughts on a cross over. I have the crossover parts you recommended and am working on the cab. I made it a touch larger to make up for stuffing and the driver, about 120 liters. (problem?) I thought I'd line the box with a very thin felt I have, then use the R-13(?) to line a couple of the inside walls as you have recommended to others.
My questions are this, I did model this and thought it looked pretty good. But, remodeled it recently to double check and the curve didn't look so good this time around. Any thoughts? I was using a ported box spreadsheet for the Mac.
A friend did some work and figured two 3" x 10" ports per cab. I'm wondering if you have any thoughts or recommendations on this. Also, any thoughts on what I'd get out of this if I went sealed?
I am only on a Mac and have no way to jump on a PC and use your software. Actually, I can find very little modeling software for the Mac. I hope you don't mind me tapping you for your extensive experience and knowledge.
Cheers!
Previous Topic: 8pi port ?
Next Topic: Eminence Gamma-15
Current Time: Thu Nov 26 19:03:07 CST 2026
