Home » Sponsored » Pi Speakers » t/s testing on sinks
Re: t/s testing on sinks [message #48093 is a reply to message #48092] Sun, 30 October 2005 18:51 Go to previous messageGo to previous message
Good job, very interesting. I think maybe the 1.0v measurements on the HL10A may have been below the sampling floor of the meter, but the higher voltage readings look reasonable. Seems like the situation is reversed on the HL10C, where the low voltage readings look more reliable than the high voltage readings. The current may have increased enough to heat the test resistor and make an impact. I suspect that was probably the case. But all in all, I think you've verified that the cooling plug is not shifting electro-mechanical parameters, so you can expect it to work well for you.
Previous Topic: request for plans and a newbie question
Next Topic: * 12pi *
Current Time: Sun Oct 18 14:37:26 CDT 2026
