Home » Sponsored » Pi Speakers » Stage 4 Update
Stage 4 Update [message #48054] Sun, 23 October 2005 22:26 Go to previous message
My fairly new Stage 4's have been getting nicer & smoother with more play. Also, this weekend replaced the stock horn compensator(?) with one made of Mills non-inductive resisitors and an Auricap. Even w/out break-in, it sounds a lot smoother and much more defined. I also found the nuts on the woofer connections had loosened a tad (all that Tupac to loosened up more than the cone), and one of the spade connections was a little loose. Good to get that stuff tightened up again- it's like re-torquing the head after 900 miles. Eventually, going to replace all the stock caps in series and solder it all up- since I'm using Paramours I don't need the high-power capability in the stock. Going to be fun....
Previous Topic: Heat exchangers Wayne
Next Topic: Pic Posting
Current Time: Sun Nov 01 12:53:36 CST 2026
