Home » Sponsored » Pi Speakers » Two Pi Towers - Placement?
Two Pi Towers - Placement? [message #47953] Tue, 11 October 2005 18:17 Go to next message
ArthurPrince is currently offline  ArthurPrince
I would like to hear from anyone who has used or is currently using the Two Pi Towers. I am curious about speaker placement, i.e. distance from walls, etc. I am also curious about what kind of room they work best in, as some speakers require rather large rooms in order to sound good.
Re: Two Pi Towers - Placement? [message #47956 is a reply to message #47953] Tue, 11 October 2005 22:01 Go to previous message
I suggest using the two towers with their backs against a rear wall, spaced 3" - 6" away from it. If they need to be placed near corners, position them a couple feet away from the corners if you can.
Previous Topic: Horn Throat Geometry
Next Topic: *7 pi version
Current Time: Sun Nov 01 14:34:26 CST 2026
