Home » Sponsored » Pi Speakers » rajeev cooling *
rajeev cooling * [message #47947] Tue, 11 October 2005 10:49 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
rajeev the heat is on . you need a driver with a screw vented pole . this is the female part then go make the male part with a simple tube atchment joined for a round aluminium disc. O better wait for the Wayne price after mass production.
Re: rajeev cooling * [message #47959 is a reply to message #47947] Wed, 12 October 2005 01:56 Go to previous messageGo to next message
Rajeev is currently offline  Rajeev
I think the screw will not give as good conduction as a tight fit male with some silicone grease , I asked wayne if this male should also have a hole in the centre for even better cooling with air passing through it .
Re: rajeev cooling * [message #47962 is a reply to message #47959] Wed, 12 October 2005 04:05 Go to previous message
Increased surface area generally makes a better interface and therefore better heat transfer. So a threaded plug would probably be sligntly better than one that is press fit. Either way, the heat conductive grease should be used for best heat transfer.
Previous Topic: *7 pi version
Next Topic: 12pi
Current Time: Sun Nov 01 11:12:18 CST 2026
