Home » Sponsored » Pi Speakers » -8* pi* Xover--
-8* pi* Xover-- [message #47920] Sun, 09 October 2005 13:20 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy.Wayne . Could use in the 8 Pi a crossover point of 3000 hz . I said this because a get a very goood price on a 4 x 10 horns that work over 2500 hz. thanks
Re: -8* pi* Xover-- [message #47921 is a reply to message #47920] Sun, 09 October 2005 16:35 Go to previous message
The crossover is optimized specifically for the components chosen and their physical locations. I cannot recommend deviations without specific analysis, but I don't think the midhorn with the Alpha 10 will reach 3kHz and provide good response. You would need to do a complete crossover redesign, and adddress the dip around 2kHz. I think for quality's sake, I'd rather attenuate the region above 2kHz and crossover there. There is also the matter of summing, and the existing design matches the mid and tweeter seamlessly. Wavelengths at 3kHz are smaller, so placement tolerances would be tighter. My gut feel is that you would be better off leaving the design as it is. I've done a lot of work to get it right.
Previous Topic: 8 Pi Question ?
Next Topic: Resources
Current Time: Sun Nov 01 16:04:34 CST 2026
