| Four Stage [message #47666] |
Mon, 05 September 2005 12:39  |
beto1
Messages: 36 Registered: May 2009
Baron |
Hi, can I use the Omega 18" in the four stage configuration? Of course, doing some litlle cabinet size modification. There is some guy who has do it? Thanks in advance, Beto
| Re: Four Stage [message #47673 is a reply to message #47672] |
Mon, 05 September 2005 22:03   |
beto1
Baron |
Ok. so as a 3 way system I can use the 18" with the omega 10" in the middle and the PSD2002 tweeter. You have designed this 3 way in one enclosure? or there is an alternative in two enclosures, one for the 18" sub bass, and the other for the mid and tweeter? Do you think that this 18" driver will need bigger rooms to fill? I guess that everybody wants bass extenssion, depending on the kind of music that one hear. With 40HZ I think, we will cover most kinds, but there is some, like organ, or some electronic music thats need the extra hz. I hear jazz and clasics (conteporary the most), but also have rocker blood in my veins, and like all kind of music. Also I'm searching for a 3 way bass reflex with the 15" driver, I supose that is a very similar enclosure. Thank you Wayne for share all this information with us, you are a very cool guy and apreciate too much your dedication. Regards, Beto By the way, can you give the frequency ranga and the sensitivity for the 3 way bass reflex 18" omega's?
| Re: Four Stage [message #47677 is a reply to message #47673] |
Mon, 05 September 2005 22:36   |
I've designed several models of three-way systems with different midrange drivers. The Alpha 10, Delta 10 and JBL 2012 are suitable. For the tweeter, use the Eminence PSD2002 or JBL 2426. Woofers you can choose from include the Eminence Delta 12LF, Delta 15, Omega 15, Omega 18, Magnum 15HO, Magnum 18HO, JBL 2226 or 2241. There are other JBL models that will work too, as well as others from other manufacturers. But the ones I've listed above are those I've tested and optimized the crossover for. The woofers don't all use the same cabinet, but there are designs for each of them. Pick your drivers and I'll send you the plans.
