Home » Sponsored » Pi Speakers » Thiel-Small Parameter Search
Re: Thiel-Small Parameter Search [message #47653 is a reply to message #47630] Fri, 02 September 2005 22:29 Go to previous message
GM is currently offline  GM
Greets!
These are car audio 'IB' sub drivers so OB, very large sealed, or aperiodic is best, with the latter yielding the highest SQ. It's specs are ideal for a 'classic' stuffed TQWT and going isobaric will keep the line's CSA reasonable, so 12" square (inside dims) should work fine and a ~93.63" pathlength will tune it to ~30 Hz if stuffed along its length with ~48 oz of R-19 fiberglass. The beauty of this design is that the specs can be off quite a bit and still perform well by adjusting the amount of stuffing.
Catalog specs:
Fs = 30 Hz
Vas = 6.83 ft^3
Qts = 1.04
Pe (RMS/max) = 75/150 W
sens = 88dB/W/m (+/- 2 dB)
nominal 8 ohms
GM
Previous Topic: Where to get Modular amps
Next Topic: Ping: ColinHester
Current Time: Sat Nov 07 03:33:51 CST 2026
