Home » Sponsored » Pi Speakers » Anyone have any Pi 8 Construction Pics?
Anyone have any Pi 8 Construction Pics? [message #47547] Wed, 24 August 2005 22:12 Go to next message
jhovis is currently offline  jhovis
I've never built horns like these and the plans don't show any internal diagrams or bracing. I'm also still a little unsure about mounting the mid driver. I have built MBOW1, Audax HT, two cylinder subs and one sealed sub, Dayton 2-way, Buschhorns.
Can someone post some construction photos of the Pi 8?
Thanks!
Re: Anyone have any Pi 8 Construction Pics? [message #47548 is a reply to message #47547] Wed, 24 August 2005 23:51 Go to previous messageGo to next message
Here are a couple links to helpful hints on the midhorn, which is the most difficult part of the cabinet. The rest is just a box, but do be sure to brace well.
Please be sure to ask questions here for anything that confuses you. One of us is sure to lend a hand.
Re: Anyone have any Pi 8 Construction Pics? [message #47550 is a reply to message #47547] Thu, 25 August 2005 09:05 Go to previous messageGo to next message
Jeff Aiken is currently offline  Jeff Aiken
Not really detailed but may help some:
Re: Anyone have any Pi 8 Construction Pics? [message #47551 is a reply to message #47550] Thu, 25 August 2005 09:33 Go to previous messageGo to next message
Jeff,
That's perfect! Thanks.
Re: Anyone have any Pi 8 Construction Pics? [message #47552 is a reply to message #47550] Thu, 25 August 2005 09:48 Go to previous messageGo to next message
Jeff, I noticed that you used one port at the bottom. My plans were a bit different w/three (I think).
Re: Anyone have any Pi 8 Construction Pics? [message #47553 is a reply to message #47548] Thu, 25 August 2005 10:53 Go to previous messageGo to next message
Thanks Wayne,
I'll be using 3/4 MDF for the cabinet and even the internal bracing. Is the midhorn also 3/4 MDF or could that be 1/2"?
Re: Anyone have any Pi 8 Construction Pics? [message #47554 is a reply to message #47552] Thu, 25 August 2005 11:40 Go to previous messageGo to next message
Yeah, I had the same plans with 3 square ports but preferred a round vent so i just calculated for that (same tuning freq.).
Good luck on yours. You won't be disappointed.
Jeff
Re: Anyone have any Pi 8 Construction Pics? [message #47555 is a reply to message #47553] Thu, 25 August 2005 12:11 Go to previous messageGo to next message
You can make the midhorn out of 3/4" stock. When bracing, use a wedge shaped piece on the top and sides of the horn flare to give even greater rigidity.
Re: Anyone have any Pi 8 Construction Pics? [message #47567 is a reply to message #47547] Thu, 25 August 2005 15:28 Go to previous messageGo to next message
Thanks again Wayne and Jeff. After seeing a few pics, I realized it is pretty simple to build. Now, I'm just tying to decided on whether I want to veneer them or wrap them with speaker fabric like Jeff's.
Re: Anyone have any Pi 8 Construction Pics? [message #47568 is a reply to message #47554] Thu, 25 August 2005 15:30 Go to previous messageGo to previous message
I marked your site. I'll try not to use up all your bandwidth;-)
Previous Topic: Wayne, a midhorn question please
Next Topic: Small(ish) wall mount for H.T.
Current Time: Fri Nov 13 05:47:03 CST 2026
