Home » Sponsored » Pi Speakers » Can this be done?
Kickass setup Jerrod [message #47515 is a reply to message #47510] Sat, 20 August 2005 10:00 Go to previous messageGo to next message
GrantMarshall is currently offline  GrantMarshall
Re: "The three horns..." [message #47518 is a reply to message #47510] Sat, 20 August 2005 11:55 Go to previous messageGo to next message
That's exactly what I was wondering. How to get to the really high freq's and stay efficient. Figured I'd use the 806A or 902B from 3500 up perched on top of the mid-hoen. Then somehow fit in a 97dB Aurum Cantus ribbon from, say, 7000.
2 16 ohm 2226 should be around 99dB, the 2123 in horn about 105 and the 902 also almost 105. Some balancing act!
Need more dB's for the '45' amp and it wouldn't hurt for the 300B.
Re: "The three horns..." [message #47519 is a reply to message #47518] Sat, 20 August 2005 12:19 Go to previous messageGo to next message
Jerrod Harden is currently offline  Jerrod Harden
Hi Bill,
It certainly is a balancing act. It took me a long time to get it right in my head. I knew I didn't want to pad the midhorn, that was the opposite of where I was trying to go. So the midhorns are run wide open with only the inductor flattening the response. The 2426J's are padded 4 db to match the midhorns and crossed at 1.6K, 3rd order. The 2404H's are crossed at 20K, 1st order. The trio makes a solid 106 db/1w and measure very well across the combined bandwidth. The most suprising part is how well the midhorns blend with the 100 db woofer section. I had to crossover the woofers much lower than anticipated to get flat response, but it measures spot on and sounds amazing. The AudioControl Richter Scale III helped out a great deal with this. It works great to smooth out the response, but I would only use the active crossover to perform low pass function. Believe it or not the woofers are crossed electronically at 90 hz, 4th order and the midhorn/woofer crossover region actually sums flat.
I'm anxious to see how your sytem evolves. Please keep us updated.
Regards,
Jerrod
Re: "The three horns..." [message #47520 is a reply to message #47519] Sat, 20 August 2005 12:57 Go to previous messageGo to next message
I just returned from a quick trip to E-Bay...........
A single 2245 would be much easier to implement. AND, the Fs is 20Hz! I had no idea. Think of it, we could move up out of the Stereophile Class "A" restricted low frequency!
Re: "The three horns..." [message #47525 is a reply to message #47520] Sun, 21 August 2005 07:14 Go to previous messageGo to next message
Yes, it appears to be quite a driver. I wonder if it has the same sound as the 2226, just better bottom octave performance. The 2226's are great in my system. Every bass line is extremely defined, not the blur you get with most woofer systems. Let me know if you get any leads on 2245's or 2242's. I've been keeping my eyes open but haven't found anything yet.
Jerrod
Re: "The three horns..." [message #47526 is a reply to message #47525] Sun, 21 August 2005 08:46 Go to previous messageGo to next message
SAme guy has another one separate auction. I'm tapped right now you go ahead and grab'm.
Re: "The three horns..." [message #47527 is a reply to message #47526] Sun, 21 August 2005 10:44 Go to previous messageGo to next message
Hi Bill,
I saw that. And only 90 miles from where I live. One needs a recone but if you could buy them right. Wonder what a professional recone runs?
Re: "The three horns..." [message #47529 is a reply to message #47527] Sun, 21 August 2005 12:14 Go to previous messageGo to next message
The C8R2245H recone kit is $200.00, so I expect you can have it reconed for $250.00.
Re: "The three horns..." [message #47538 is a reply to message #47527] Wed, 24 August 2005 08:37 Go to previous messageGo to next message
dwkurfma is currently offline  dwkurfma
JBL 2245 H - 18" Subwoofers. 8 ohms. 400 watt. Excellent condition. SPU385 $600.00 pair [Jamminjersey.com] I really don't have experience with the 2245 but it really is very similar to the 15" 2235 which allows a tremendous range of tuning options and does sound great.
Dan
Like the JBL K2 S5800 [message #47549 is a reply to message #47502] Thu, 25 August 2005 08:13 Go to previous message
JBL has an over/under speaker that has gotten some very good reviews. Might make for a good concept model for what you are trying to do.
Previous Topic: home karaoke speaker
Next Topic: Wayne, a midhorn question please
Current Time: Fri Nov 13 07:12:02 CST 2026
