Home » Sponsored » Pi Speakers » tuning the Alpha 10"
tuning the Alpha 10" [message #47483] Tue, 16 August 2005 08:55 Go to next message
Black is currently offline  Black
i would like to tune a 4 cu ft box for the alpha 10" to 35 Hz, can anyone tell me the L & W of the port, i would prefer a rectangle port. i can't do the Calculation
thanks
zeno
Re: tuning the Alpha 10" [message #47484 is a reply to message #47483] Tue, 16 August 2005 09:56 Go to previous messageGo to next message
You can use a 4" diameter, 3½" long. There's a formula and simple program to calculate the Helmholtz frequency in the post called "Two Pi with off-sized speaker box."
Re: tuning the Alpha 10" [message #47485 is a reply to message #47484] Tue, 16 August 2005 10:07 Go to previous messageGo to next message
hi wayne, i intend to use the alpha 10" with a oris horn ( coral beta 6 fullrange driver ) do you have any suggestion on how to cross them?
zeno
Re: tuning the Alpha 10" [message #47486 is a reply to message #47485] Tue, 16 August 2005 10:32 Go to previous messageGo to next message
If I remember, the Oris horn can be used down to around 250Hz. If you crossover there, wavelegth is about 4½ feet long. I'd probably use a simple first-order filter, just a 6.0mH coil in series with the woofer. You can expect summing to be good if the woofer is placed directly underneath the Oris horn.
that seem easy [message #47487 is a reply to message #47486] Tue, 16 August 2005 10:33 Go to previous messageGo to next message
thanks wayne
4 cu ft @ 35Hz. Isn't that a 2PI Tower? (nt) [message #47488 is a reply to message #47483] Tue, 16 August 2005 14:28 Go to previous messageGo to next message
Pretty close [message #47489 is a reply to message #47488] Tue, 16 August 2005 15:11 Go to previous messageGo to next message
A two π tower is a little larger and tuned a little higher, but not much.
Re: tuning the Alpha 10" [message #47496 is a reply to message #47483] Wed, 17 August 2005 07:33 Go to previous messageGo to next message
Zeno, can I ask why you've elected to use the Alpha10? It is because you already have one lying around?
Re: tuning the Alpha 10" [message #47498 is a reply to message #47496] Wed, 17 August 2005 11:31 Go to previous messageGo to next message
thatis one of the reason, i can try any other but i am using a 2A3 amp
Re: tuning the Alpha 10" [message #47499 is a reply to message #47498] Wed, 17 August 2005 11:51 Go to previous message
I was going to suggest the Delta12LF that's used in the Theatre-3 and use that alignment. I found it to have tighter bass than the Alpha10 and allows for a smaller cabinet. However, the Alpha-10 is a much better choice if you're using a set of 2A3 amps. The "looseness" I found with the Alpha-10, when compared with the Delta12LF, may actually work in your favour when used with such a low-powered amp.
A set of Wayne's corner horns would work well in your case too. However, already having the driver in hand is a pretty good reason.
Gar.
Previous Topic: What if the "live cabinet" Co's. like Audio Note are right?
Next Topic: Speaker Voice Coil Cooling System Valve
Current Time: Fri Nov 13 05:33:07 CST 2026
