Home » Sponsored » Pi Speakers » Speaker Voice Coil Cooling System Valve
Re: Speaker Voice Coil Cooling System - Heat Sink - Photos [message #47444 is a reply to message #47442] Sun, 07 August 2005 02:39 Go to previous messageGo to next message
Sounds good, keep us posted.
Re: Speaker Voice Coil Cooling System - Heat Sink - Photos [message #47447 is a reply to message #47444] Sun, 07 August 2005 11:58 Go to previous messageGo to next message
Monomer is currently offline  Monomer
Will do
Where'd you get the greese from? Any way to find it locally?
Re: Speaker Voice Coil Cooling System - Heat Sink - Photos [message #47448 is a reply to message #47447] Sun, 07 August 2005 12:09 Go to previous messageGo to next message
Check the local electronic supply in your area. Ask 'em for heat sink compound. It's the same stuff you apply to the back of a power transistor when mounting it on a heat sink.
Re: Speaker Voice Coil Cooling System - Heat Sink - Photos [message #47449 is a reply to message #47448] Sun, 07 August 2005 13:19 Go to previous messageGo to next message
I know
I've just never seen a tub of the stuff (It usually comes in small tubes)
I suppose RatShack would have it; At a price.
Re: Speaker Voice Coil Cooling System - Heat Sink - Photos [message #47450 is a reply to message #47449] Mon, 08 August 2005 20:23 Go to previous messageGo to next message
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=276-1372
about 3ish tubes should do?
Now (upon acually getting started on building the cab) It looks as if room is limited. I cant wait to get the mag's here and startup this project.
Re: Speaker Voice Coil Cooling System - Heat Sink - Photos [message #47451 is a reply to message #47450] Mon, 08 August 2005 22:10 Go to previous messageGo to next message
That's the stuff.
Re: Speaker Voice Coil Cooling System - Heat Sink - Photos [message #47452 is a reply to message #47451] Tue, 09 August 2005 15:57 Go to previous messageGo to next message
Got the stock today.
Mine are going to be made out of 1 Inch roundstock, and will be one solid piece.
I dont know how I'm going to do the holes (I'm not all to good with the indexing head)
Re: Speaker Voice Coil Cooling System - Heat Sink - Photos [message #47453 is a reply to message #47452] Tue, 09 August 2005 16:15 Go to previous messageGo to next message
Very good, sounds like you're on your way.
How far is the panel from the magnet in your basshorn?
Re: Speaker Voice Coil Cooling System - Heat Sink - Photos [message #47457 is a reply to message #47453] Wed, 10 August 2005 16:38 Go to previous messageGo to next message
I'll tell ya when the speakers get here.
I cant afford a gaint peice of alumn. but I do have some heatsinks here that look to be a good size for it.
Re: Speaker Voice Coil Cooling System - Heat Sink - Photos [message #47471 is a reply to message #47457] Sun, 14 August 2005 21:17 Go to previous messageGo to previous message
Mahendra Palesha is currently offline  Mahendra Palesha
There r two poles of the voice coil. If we make one pole directly earthed to the body of the woofer then what will be the effect? will the body of the woofer not work as a heatsink?
Previous Topic: tuning the Alpha 10"
Next Topic: A few pics to share
Current Time: Thu Nov 19 09:26:40 CST 2026
