Home » Sponsored » Pi Speakers » Suggestions for Active crossover for Theater 4 pi (long)
Suggestions for Active crossover for Theater 4 pi (long) [message #47423] Wed, 03 August 2005 06:40 Go to previous message
Frank Mena is currently offline  Frank Mena
Right now I have my Foreplay II & Paramours (with iron upgrade) with Theater 4 pi's and this system really kick's serious butt. Try as I might, my room dimensions/characteristic's won't let me get that bit of extra bass I would like to fill out the bottom end.
So I was thinking of looking at a two way tube(Marchand?)active crossover in addition to adding an active sub to the system. It would look like >> CD player then Foreplay then Paramours then active crossover then 4 Pi's with one out of the active X-over going to the active sub.
Is this be the correct order? or is it active-x-over then amps then speaker & sub? I would still use the passive theater 4 pi crossover? No? Yes? Any suggestions for an active sub that would blend well with the above system? Parts Express DIY? And FINALLY the last question, does an active crossover increase the depth of image (or 3 D soundscape if you will)?
I have to say that I could easily live with the way the system is right now with no changes, but half of the fun for me is seeing what tweaks I can do to change this and that & see what happens as a result. These speakers are truely awesome.
Thanks all!!
Previous Topic: 12 π basshorn - just about ready for prime time
Next Topic: Pi 4 Theater with Coral H30 Horn Tweeter 3-20kHz 94dB/W-m
Current Time: Thu Oct 22 20:33:10 CDT 2026
