Home » Audio » General » Polyphemus is on the loose
Polyphemus is on the loose [message #4740] Sun, 16 March 2008 12:44 Go to next message
Cyclops ping [message #4741 is a reply to message #4740] Sun, 16 March 2008 22:20 Go to previous messageGo to next message
Bill, That has to be one of the best reviews ever!!! I'm still laughing. Constantine will get some letters on this one.....C
Re: Polyphemus is on the loose [message #4742 is a reply to message #4740] Tue, 18 March 2008 11:41 Go to previous messageGo to next message
Great review, Bill! Thanks for pointing it out.
I've been dragging my feet on buying a phono stage for a long time, so I'm interested. I have built-in phono stages in a couple of my preamps, so I'm not stuck, but I do want a nice stand-alone phono stage. Is this available only as a finished unit, or can you buy it as a kit? Maybe just the PCB and parts? If only available as a finished product, does it come in different cabinet options?
Re: Polyphemus is on the loose [message #4743 is a reply to message #4742] Tue, 18 March 2008 15:35 Go to previous messageGo to next message
Just the finished product as you see it. Set it and forget it!
For a kit, there's no substitute for the Hagerman Cornet2, $$$ or sound. Plus it's fun to fool with. $99 for the board and another $250 and up for the parts. I've built it in a wooden box and also a Hammond 10x17x3 which accomodates step-up transformers.
As you well know, different 47k input resistors, coupling and output caps, and tube rolling make the Cornet a lot of fun. Even changing the rectifier makes a difference.
Talk to Steve Brown, too, he loves the circuit he built based on, I think, an Allen Wright design.
Re: Polyphemus is on the loose [message #4744 is a reply to message #4743] Tue, 18 March 2008 17:18 Go to previous message
You're right about Steve's circuit. He mentioned it earlier, and I'm interested. I'll also look again at the Hagerman.
Previous Topic: Lone Star Audiofest - Exhibitors and Activities
Next Topic: Philco Stereophonic Hi-Fi PhonoRama VI
Current Time: Fri Nov 27 05:31:19 CST 2026
