Home » Sponsored » Pi Speakers » LT250 Horn Flare?
LT250 Horn Flare? [message #47369] Fri, 22 July 2005 20:07 Go to previous message
Wayne,
Can you tell me anything about the Eminence LT250 horn? I understand you've used this in the past in designs where space was tight.
I've been trying to come up with a design for a center channel to match my Theatre-3's and can't find a way to do it with the H290/295. The speaker has to be under 18" and the horn over driver arrangement does not fit.
I'm thinking a horizontal MTM arrangement, with a 12LF on either side of a LT250. Do you think the 60 degree horizontal dispersion is too narrow? Will sensitivity for the PSD2002 increase with this horn vs. the H295 due to the more confined dispersion?
thanks,
Gar.
Previous Topic: Plans For 1 PI
Next Topic: Active xover's
Current Time: Sun Nov 15 09:22:05 CST 2026
