Home » Sponsored » Pi Speakers » Could I get a copy of the Theater Series 7 PI corner horns?
Could I get a copy of the Theater Series 7 PI corner horns? [message #47368] Fri, 22 July 2005 20:00 Go to next message
Matt Presley is currently offline  Matt Presley
I also have a question. can you build them without the corner "dog house roof" part in order to cut down on size for hauling around in a car? I assume you could just put the box the correct distance from the corner but I also imagine that the "roof" could provide vital rigidness for the horn. Just wondering. -Matt
You've got mail! [message #47371 is a reply to message #47368] Sat, 23 July 2005 00:55 Go to previous message
The rear section of a π cornerhorn bass bin is just a positioning device so you can remove it if you want to. But the midhorn goes on top too, and it will probably be a bit clumsy without it. So I'd leave it as it is.
Previous Topic: Three Pi Pro
Next Topic: Reflex volume of 4PI Pro - about 2.5 ft^3 ?
Current Time: Fri Nov 13 16:14:35 CST 2026
