| Mangum 12 HO as a midrange [message #47327] |
Tue, 19 July 2005 10:17  |
Paul Spencer
Messages: 4 Registered: May 2009
Esquire |
After searching the forum I'm confused re: Magnum 12. Is it suitable to be used as a midrange driver? From the datasheet it looks like an excellent driver with a response flatter than many hifi mids, yet I've heard comments that it's not suitable as a mid ... It appears the cheapest HE driver I can find that has a shorting ring and flat response. Comments? The Delta 12LF also looks good as a midrange (to me at least) ... any comments on how this driver compares? As I understand, the off axis response of a 12" is better ...
| Re: Mangum 12 HO as a midrange [message #47330 is a reply to message #47329] |
Tue, 19 July 2005 11:59   |
Paul Spencer
Esquire |
2 questions: 1) when you posted that it's not a good mid, were you referring to another magnum? 2) how does it compare to high end hifi drivers (Scan Speak, Seas, etc) in the fidelity department, excluding obvious advantages such as efficiency and output?
| Re: Mangum 12 HO as a midrange [message #47333 is a reply to message #47331] |
Tue, 19 July 2005 14:15   |
Shorting rings are most effective at midbass and midrange frequencies. At very low frequencies, they aren't usually large enough and at very high frequencies, harmonics are ultrasonic and can't be heard. So shorting rings are best in woofers and midrange drivers.I can hear the difference right away. I always prefer a woofer with a shorting ring to a similar one without. If you like SET amps, you may like a midrange without a shorting ring but you'll probably still like a woofer that has one. I've heard some amps that I liked the mid to have a shorting ring and some amps that seemed to be better without one. But I always prefer the woofer to have a shorting ring, if I have a choice. Perhaps the reason is the distribution of harmonics - A woofer's harmonics would be smack dab in the vocals and a midrange's harmonics would be shifted up into the overtone range or above. As for comparison of the two specific woofers, Magnum 12HO and Delta 12LF, there's another thing you should consider too. The Delta 12LF and the Magnum 12HO are tuned differently. The Delta 12LF is tuned to use medium to large cabinets and is made so that it has low f3 in suitable cabinets. It's a great woofer for the price, and is suitable for a variety of applicatons. The Magnum 12HO cannot be made to work at very deep bass frequencies. You could align a cabinet to squeeze deep bass out of it, but it's not made for that purpose. It is made to be used in relatively small cabinets that aren't required to go very deep. The designer will probably incorporate it with a bass bin that goes lower. You could also use it for a small monitor but f3 isn't going to be all that low.
| Re: Mangum 12 HO as a midrange [message #47339 is a reply to message #47333] |
Tue, 19 July 2005 23:08   |
Matts
Messages: 359 Registered: May 2009
Grand Master |
Wayne, When you talk about the shorting ring reducing harmonics, you just mean the harmonics created by the speaker "distortion", not those in the music, right? Matts
| Re: Mangum 12 HO as a midrange [message #47341 is a reply to message #47333] |
Wed, 20 July 2005 04:05   |
Paul Spencer
Esquire |
Thanks for the quick and detailed response! My application: I'm looking for a mid to match up with my existing 12" subs. I'm considering 2 options: 1) sealed box mid (Q.707) crossed actively at 80 Hz 2) vented midbass getting down as low as 50 or 60 Hz #1 allows me to stuff the box and kill the back wave #2 will probably give me better bass as I don't think my subs are that great in the upper bass Thoughts anyone?
