Home » Sponsored » Pi Speakers » 12 π basshorn - just about ready for prime time
Re: 12 π basshorn - just about ready for prime time [message #47287 is a reply to message #47284] Fri, 08 July 2005 06:59 Go to previous messageGo to previous message
Walt is currently offline  Walt
Perhaps I am missing something but why don't you make the front chamber smaller: 20 litres instead of 50 litres. That will give a much flatter response which is more easy to use with standard subwoofer amps with build in bassboost. Perhaps you can open up the throat to 450cm2.
I know the large 50 litre frontchamber will give a higher SPL max around 30Hz but for home use I would think the 20 litres frontchamber version sound better. Response in a corner will be +/- 2dB from 30-100Hz...
Best regards,
Walt
Previous Topic: pi 2 monitor...wayne and others- plans for 1 pi and 2pi monitor pls
Next Topic: Suggestions for Active crossover for Theater 4 pi (long)
Current Time: Thu Oct 22 21:30:25 CDT 2026
