Home » Sponsored » Pi Speakers » flush mount or not?
Re: reinforcement.... [message #47277 is a reply to message #47276] Thu, 07 July 2005 11:39 Go to previous messageGo to previous message
a good thing about this type of reinforcement, assuming you just put another layer of wood on the inside around the hole, is t-bolts will hold it in place rather than fighting it. So it should be easy to do- a little glue to start out with and get the hole right, then the t-bolts to hold the speaker on. Will look very nice.
What amps are you using these with?
Previous Topic: Near Field or Mid Field Moniters
Next Topic: studio one
Current Time: Mon Nov 02 06:40:55 CST 2026
