Home » Sponsored » Pi Speakers » Near Field or Mid Field Moniters
You've got mail! [message #47261 is a reply to message #47260] Sun, 03 July 2005 11:58 Go to previous messageGo to next message
The sound is a lot like the 1980's model of the one π with the JBL 2115, but it will handle a lot more power so you can push it further. I really like these little speakers.
Re: one more question... [message #47262 is a reply to message #47261] Sun, 03 July 2005 13:25 Go to previous messageGo to next message
Have you tried them with your Paramours? I noticed the 2206 has a 95dB efficiency.
Re: one more question... [message #47263 is a reply to message #47262] Sun, 03 July 2005 13:32 Go to previous messageGo to next message
I sold the Paramours. But I've listened to them on a couple other SET amps and they sound great, even with just one watt.
Re: Near Field or Mid Field Moniters [message #47264 is a reply to message #47251] Mon, 04 July 2005 08:56 Go to previous messageGo to next message
wmict is currently offline  wmict
That would be great Wayne, Thanks!
Re: one more question... [message #47265 is a reply to message #47263] Mon, 04 July 2005 14:30 Go to previous messageGo to next message
Wayne,
I'm replacing the studio Pi Two's- my son's taking them to college. Am figuring these will not give quite as much bass as the 2 Pi's- is that correct? If I got these, I'd build a sub later and have killer sound, or go with one of the Four Pi models instead of all that?
Hope you're having a Happy Fourth- gotta go grill Red, White & Blue burgers (roquefort cheese inside the meat!).
Cheers,
Matts
You've got mail! [message #47266 is a reply to message #47264] Mon, 04 July 2005 22:51 Go to previous messageGo to next message
Re: one more question... [message #47267 is a reply to message #47265] Mon, 04 July 2005 23:00 Go to previous messageGo to next message
The two π tower most certainly goes deeper but the Studio two π has slightly higher f3 than the Pro three π. Both are good sounding speakers, but the addition of a shorting ring in the Pro three π is a plus.
Re: one more question... [message #47268 is a reply to message #47267] Tue, 05 July 2005 11:00 Go to previous messageGo to next message
so if the regular Studio Two in quarter space in my room has sufficient bass, then the Pro Three would have slightly deeper bass at same volumes?
Re: one more question... [message #47269 is a reply to message #47268] Tue, 05 July 2005 13:36 Go to previous messageGo to next message
Yes, the two speakers are similar but the Studio two π has about 1dB rise in the bottom octave and the Pro three π goes a little bit deeper. The biggest difference is the fact that the Pro three π has a woofer with a flux control ring.
Re: Too many options! [message #47270 is a reply to message #47269] Wed, 06 July 2005 10:52 Go to previous message
Good problem to have. Sounds like these Pro Three's may be a very good option for me... or any of the Fours... or the Theatre Three's.... Have 'til the end of the month to decide!
Previous Topic: Pi to 83,431 Places
Next Topic: flush mount or not?
Current Time: Mon Nov 02 08:52:44 CST 2026
