Home » Sponsored » Pi Speakers » pi stagea 4 construction
Re: pi stagea 4 construction [message #47070 is a reply to message #47067] Mon, 06 June 2005 13:44 Go to previous messageGo to previous message
The tweeter displaces about 150 cubic inches. You can shrink the box that much if you want, it's about an eighth inch from each side. But the shift from 150 cubic inches is very small, and the direction is downward, which is better than upward.
More important is that you shift the woofer up so that the distance between it and the tweeter is maintained. What I would suggest you do is to keep the box size the same, and use the additional room you'll gain by installing a brace from the front to back panels.
Previous Topic: seven Pi
Next Topic: Will bi-amping work like this?
Current Time: Mon Nov 02 06:54:20 CST 2026
