Quality of the op amps used [message #47003 is a reply to message #47002] |
Wed, 01 June 2005 15:26 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
spkrman57
Messages: 522 Registered: May 2009
Illuminati (1st Degree) |
Bill, I have not found a SS electronic crossover that has been blessed for audiophile use that did not cost near a $1000.00! However the Steve Bench tube powered electronic crossover would be a better match to the level of quality you are using. Ron
Re: Question about this active crossover? [message #47039 is a reply to message #47016] |
Fri, 03 June 2005 15:51 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) |
GarMan
Messages: 960 Registered: May 2009
Illuminati (2nd Degree) |
The Bugle's a great design and the use of OPA2134 opamps probably helps its sound too. Replace the stock opamps in this $100 XO with OPA2134's and you may end up with something very decent. My experience with active XO and multiamp-ing is that even if the XO is so-so, you'll still get a huge improvement. The only reason why I don't have my system in this configuration full-time is that my wife finds it hard to use.
