Home » Sponsored » Pi Speakers » Another pi midhorn question.
Re: Another pi midhorn question. [message #46844 is a reply to message #46841] Sat, 07 May 2005 12:52 Go to previous messageGo to previous message
Overall, it's about eleven inches, depending on the thickness of the wood of the throat mount plate. Using a little trigonometry, you can find the length you're looking for using the formula length = cos45°(14.5"), about 0.707 times the length of the side 14.5", or approximately 10.25". If you use these figures, the mouth will actually be a little larger than 12" x 24", which is just fine.
Previous Topic: 7Pi placement in my room
Next Topic: Pink Noise Vs. sweeps for measurements
Current Time: Wed Nov 04 10:16:18 CST 2026
