Home » Sponsored » Pi Speakers » What kind of tweeterhorn does the 7pi use?
Re: Thx Wayne. [message #46781 is a reply to message #46767] Wed, 27 April 2005 17:53 Go to previous messageGo to previous message
Kim Schultz is currently offline  Kim Schultz
I have a cheap driver from Monacor, but it models very closely to the Delta 10 when simulated in Hornresp.
SP-10/100PA
PA bass-midrange speaker, 200WMAX, 8Ω
With high power capability and linear frequency response.
Technical datasheet
Impedance (Z) 8Ω
Resonant frequency (fs) 65Hz
Max. frequency range f3-5,000Hz
Music power 200WMAX
Power rating (P) 100WRMS
SPL (1W/1m) 98dB
Suspension compl. (Cms) 0.18mm/N
Moving mass (Mms) 31g
Mech. Q factor (Qms) 4.10
Electr. Q factor (Qes) 0.42
Total Q factor (Qts) 0.38
Equivalent volume (Vas) 32 l
DC resistance (Re) 6.9Ω
Force factor (BxL) 14.4Tm
Voice coil induct. (Le) 0.75mH
Voice coil diameter 50mm
Voice coil former Kapton
Linear excursion (XMAX) ±2.5mm
Eff. cone area (Sd) 350cm2
Magnet weight 50oz.
Weight 4.1kg
I´m having problems with your program, trying to figure out the pi alignment for the 15" driver.
SP-15/300PA
High-quality PA speakers for universal stage and professional DJ applications. Excellent manufacture and optimum specifications for powerful bass-reflex speaker systems.
PA bass speaker, 600WMAX, 8Ω
Very high efficiency for bass applications, max. bass pressure in the medium bass range in astonishingly small cabinets.
Technical datasheet
Impedance (Z) 8Ω
Resonant frequency (fs) 38Hz
Max. frequency range f3-4,500Hz
Music power 600WMAX
Power rating (P) 300WRMS
SPL (1W/1m) 101dB
Suspension compl. (Cms) 0.23mm/N
Moving mass (Mms) 88g
Mech. Q factor (Qms) 5.44
Electr. Q factor (Qes) 0.29
Total Q factor (Qts) 0.27
Equivalent volume (Vas) 232 l
DC resistance (Re) 6.8Ω
Force factor (BxL) 22.2Tm
Voice coil induct. (Le) 1.3mH
Voice coil diameter 78mm
Linear excursion (XMAX) ±3mm
Eff. cone area (Sd) 855cm2
Magnet weight 65oz.
Weight 7.5kg
Previous Topic: Stage and Pro three π
Next Topic: Be sure to give some fancy speakers the..........
Current Time: Fri Oct 16 21:59:14 CDT 2026
