Home » Sponsored » Pi Speakers » Unity horns???? what is a Pi Speaker horn?
Re: Unity horns???? what is a Pi Speaker horn? [message #46749 is a reply to message #46748] Sat, 23 April 2005 20:28 Go to previous messageGo to previous message
If you are interested in Unity horns, you might bring them up on the High Efficiency forum because I do not use them. The Unity device is a horn that Tom Danley came up with that has midrange and tweeters sharing the same flare. It's an interesting concept, but since several drivers fire into a common chamber, their interaction is highly coupled and phasing in the overlap range is extremely critical. It's a delicate balancing act, tenable at low frequencies but more unlikely as the crossover frequency goes up. In its best trim, everything is right on the edge and any shifts in operational parameters due to component tolerance, age or power heat cycles can throw it off. The midrange drivers not being loaded at the apex necessarily cause more internal reflections too, so this configuration is just not for me.
As for information about π Speakers, I suggest doing some reading here, because there is a lot of information. After you have looked around a while, I'd be happy to respond to any specific questions you have.
Previous Topic: The Royal on the way to Tulsa
Next Topic: Stage and Pro three π
Current Time: Thu Nov 26 12:33:40 CST 2026
