Home » Sponsored » Pi Speakers » Deltalite vs other Eminence drivers
Deltalite vs other Eminence drivers [message #46687] Sun, 10 April 2005 12:29 Go to next message
Henry Eng is currently offline  Henry Eng
Can someone who has heard the Deltalite 12 or 15-inch driver and other Eminence drivers make a comment on whether the Delta's are good compared to their higher-end models? Obviously there will be compromises...
Thanks
-Henry
Re: Deltalite vs other Eminence drivers [message #46690 is a reply to message #46687] Sun, 10 April 2005 19:59 Go to previous messageGo to next message
They're pretty good, but midrange response is reduced because of the lack of a radiating dust cap.
Radiating dust caps, Wayne? [message #46698 is a reply to message #46690] Mon, 11 April 2005 15:27 Go to previous messageGo to next message
Garland garland is currently offline  Garland garland
...Awhile back I mentioned that I had enjoyed the effect of adding a layer of a felt like material to the dustcaps of my Delta 15A's. I experienced a cleaning up of the midrange (from what I don't really know). Could this be due to reduced midrange responce similar to what your talking about here?
G.
Re: Radiating dust caps, Wayne? [message #46700 is a reply to message #46698] Mon, 11 April 2005 21:48 Go to previous messageGo to next message
Could be, it's hard to say. On the Eminence drivers without a radiating dust cap, midrange output is significantly reduced.
Re: Radiating dust caps, Wayne? [message #46702 is a reply to message #46700] Tue, 12 April 2005 10:51 Go to previous messageGo to next message
Which Eminence drivers have and don't have the cap you are refering to?
Re: Radiating dust caps, Wayne? [message #46703 is a reply to message #46702] Tue, 12 April 2005 12:18 Go to previous messageGo to next message
The Magnums and the neodymium drivers have mesh dust caps, so they don't radiate any sound.
Re: Radiating dust caps, Wayne? [message #46724 is a reply to message #46703] Sun, 17 April 2005 14:09 Go to previous messageGo to next message
Crazy Dave is currently offline  Crazy Dave
Hi Wayne,
Given the reduced midrange output, what would the optimum Crossover be for these drivers?
Dave
Re: Radiating dust caps, Wayne? [message #46725 is a reply to message #46724] Sun, 17 April 2005 17:04 Go to previous messageGo to next message
They're all different, but I don't use any of them as midrange or midwoofers. I don't think the Magnums are suitable for two-way systems, they must be used with mids. The neodymium parts must be crossed over to mids pretty low too.
Re: Radiating dust caps, Wayne? [message #46731 is a reply to message #46725] Sun, 17 April 2005 21:27 Go to previous messageGo to next message
So they are more suitable as 3-ways, or if used as a 2-way, the tweeter must be able to be crossed low. Maybe 800Hz? That woud be out of line with you design paramiters of keeping the crossover out of the voice range.
Thanks for the response,
Dave
Re: Radiating dust caps, Wayne? [message #46732 is a reply to message #46731] Sun, 17 April 2005 22:06 Go to previous messageGo to previous message
The neodymium 2510 can be crossed over at 1kHz, even on the midhorn. But I'm crossing the Magnums lower than that, and using them purely as woofers.
Previous Topic: ZOMAX 1044 COMPRESSION DRIVER
Next Topic: Really are more than a pretty face
Current Time: Fri Nov 20 02:41:09 CST 2026
