Home » Sponsored » Pi Speakers » L-Pad Configs
L-Pad Configs [message #46678] Fri, 08 April 2005 10:57 Go to next message
Hi Wayne,
Can you explain to me the differences between the two types of L-Pad configurations.
Type I: "Traditional" type with R-series followed by R-paral and driver.
Type II: "PI" type with R-paral followed by R-series and driver.
From what I see, Type I is much more sensitive to resistor values when high levels of attenuation is required and also requires very low values for R-paral, which are hard to find.
Type II seems to be more "stable" and tolerant of resistance variations and uses easier to find values.
Re: L-Pad Configs [message #46679 is a reply to message #46678] Fri, 08 April 2005 11:05 Go to previous message
There are several things that resistance in the circuit can be made to do. It can be used to provide attenuation and it can also be used to set the Q of the circuit. So the differences in values and configuration are what set those things. In some cases, all that is needed is a voltage divider, but in other cases the Q of the circuit is modified to tailor response.
Previous Topic: He He....I traded Speakerman right out of his undies!!
Next Topic: zobel network..many doubts!!
Current Time: Wed Oct 21 00:49:36 CDT 2026
