Home » Sponsored » Pi Speakers » GE 97F motor run caps on tweeters...Yum!
GE 97F motor run caps on tweeters...Yum! [message #46625] Thu, 31 March 2005 16:34 Go to next message
GarlandGarland is currently offline  GarlandGarland
After a bit of break-in, all I can say is the motor-run caps in series with the compression driver is awesome! -Much more musicality and resolution. Complex musical lines are much easier to follow! You guys have to try them! Grainger and Newark have 'em.
G.
Re: GE 97F motor run caps on tweeters...Yum! [message #46629 is a reply to message #46625] Thu, 31 March 2005 18:41 Go to previous message
Thanks for the tip. I will try them for sure. I have several parts coming from Kimber, Solen, Jantzen and Erse for a first test. I also plan to try a half dozen other brands. Last time I compared components was several years ago, so I plan to look at them again over the next few months.
Previous Topic: 2 Pi Dimensions
Next Topic: Theatre 4 Pi Plans and Questions
Current Time: Sat Oct 31 23:08:36 CDT 2026
