Home » Sponsored » Pi Speakers » Dimensions
Dimensions [message #46563] Thu, 24 March 2005 16:29 Go to next message
Are all the dimensions for the corner horns list on the web site accurate? They are listed as:
Theater 7-pi: 66"x24"x36"
Stage 7-pi: 54"x18"x30"
Premium 7-pi: 54"x18"x30"
Audiophile 7-pi: 54"x18"x30"
Professional 7-pi: 54"x18"x30"
Stage 7-pi 18: 66"x24"x18"
Premuium 7-pi 18: 66"x24"x36"
Audiophile 7-pi 18: 66"x24"x36"
Professional 7-pi 18: 66"x24"x36"
I was about to order the Theater 7-pi kits but then noticed the dimensions are much larger than the others. I just wanted to verify the sizes before I ordered, since size is a concern for me.
Thanks
Re: Dimensions [message #46565 is a reply to message #46563] Thu, 24 March 2005 16:34 Go to previous messageGo to next message
The T/S parametres for the Delta15 is very different from the Omega, Kilomax or JBL. Notices how the Theatre 4's are also much larger than the Stage, Premium, or Professional?
Re: Dimensions [message #46566 is a reply to message #46565] Thu, 24 March 2005 16:36 Go to previous messageGo to next message
I figured as much, but I didn't want to make any assumptions.
Thanks
Re: Dimensions [message #46567 is a reply to message #46563] Thu, 24 March 2005 16:41 Go to previous messageGo to next message
The Theater Series seven π is larger than the Stage, Premium, Audiophile or Pro sevens, that is true. The bass bin for the Theater seven π is nearly four feet tall, and then you have a midhorn and tweeter on top of that. The bass bin for the Stage, Premium, Audiophile and Professional Series seven π speakers are about a foot shorter. I'd be happy to send you the plans so you can compare them, if you want.
Re: Dimensions [message #46568 is a reply to message #46566] Thu, 24 March 2005 16:43 Go to previous messageGo to next message
If you haven't seen a cornerhorn, you'll be amazed how they seem to snuggle back into the corner and not take up much room at all. These are monster dimensions, which is good acoustically, but difficult to fit into a room unless they're packed away into corners. But when you put them in corners, they seem to take up very little room at all.
Re: Dimensions [message #46569 is a reply to message #46567] Thu, 24 March 2005 17:13 Go to previous messageGo to next message
Thanks for the offer. You've sent me some drawings already and I made a cardboard mockup. They (the drawings) are labeled sevenPi_Magnum so I'm guessing they are for the Audiophile series. I'd prefer the shorter version for WAF reasons so no need to send Theater drawings.
Re: Dimensions [message #46571 is a reply to message #46566] Thu, 24 March 2005 23:01 Go to previous messageGo to next message
Numbers on a page are still just numbers. I recommend you make mock-ups out of cardboard boxes to get a true sense of the dimensions before cutting any wood. Compared to building the actual speakers, the cardboard mockups are a breeze to do and will save you from any surprises.
Re: Dimensions [message #46574 is a reply to message #46569] Fri, 25 March 2005 09:06 Go to previous messageGo to next message
Actually, in retrospect, would you mind sending the drawings for the Theater version? The Theater's are already a bit more money than I originally intended to spend, so I'm not sure I want to pay the extra $70 for the Stage version. The flip side is that I wanted to be able to upgrade later, which would, at minumim, require the Stages.
Re: Dimensions [message #46579 is a reply to message #46574] Fri, 25 March 2005 12:48 Go to previous messageGo to next message
Sorry, but I can't remember your E-Mail address. Please tell me and I'll send plans.
Re: Dimensions [message #46624 is a reply to message #46571] Thu, 31 March 2005 14:07 Go to previous message
Actually did that for the smaller 7's. They are huge, which is why I was concerned about the larger Theater 7's.
Previous Topic: 2pi Tower
Next Topic: 2 Pi Dimensions
Current Time: Fri Nov 13 07:37:23 CST 2026
