Home » Sponsored » Pi Speakers » Bypassing protective lamp in crossover?
Bypassing protective lamp in crossover? [message #46535] Tue, 22 March 2005 09:43 Go to next message
Anyone ever tried bypassing the protective lamp in the PI Speaker crossover with a straight wire? Any noticable improvement to the sound? I know the lamp is there to protect the HF driver, but my drivers never see anything close to their power ratings.
Re: Bypassing protective lamp in crossover? [message #46537 is a reply to message #46535] Tue, 22 March 2005 10:48 Go to previous message
Try it, you'll be very surprised. Since it is about 1.8 ohms cold, I expected a noticeable difference would result from shorting it. If there were no other crossover components, it would raise the Q of the system. But the resistance is ahead of the reactive components in the crossover and is decoupled by them. It doesn't interact with the system as much as if it were after the crossover, in the position of R1. Changes in R1 resistance will make a measurable and noticeable difference. But ahead of the crossover, it doesn't.
Previous Topic: guitar speaker
Next Topic: Hey, Wayne, You Should . . .
Current Time: Wed Oct 21 17:06:29 CDT 2026
