Home » Sponsored » Pi Speakers » alpha 8 enclosure volume
alpha 8 enclosure volume [message #46523] Sun, 20 March 2005 09:35 Go to next message
paul d is currently offline  paul d
On the eminence website, they say the recommended enclosure volume for the alpha 8 is 1.1 to 1.8 cf. Your design is 1 cf for the external dimension of the cabinet, so maybe its .8 or.9 cf for the internal volume.
Why go with a smaller box than recommended?
and
How does the alpha 8 sound in a 1.8 cf cabinet?
Re: alpha 8 enclosure volume [message #46524 is a reply to message #46523] Sun, 20 March 2005 09:50 Go to previous messageGo to next message
The Alpha 8 works best in 0.5ft3 to 2.0ft3 tuned to 55Hz. It really is a midrange driver and can be used with a very small rear chamber, but you can coax them to produce bass with a good response curve in larger cabinets up to two cubic feet.
Re: alpha 8 enclosure volume [message #46525 is a reply to message #46524] Sun, 20 March 2005 09:57 Go to previous messageGo to next message
Thanks!
1 Pi Minitower [message #46534 is a reply to message #46524] Tue, 22 March 2005 04:04 Go to previous messageGo to next message
Oscarl is currently offline  Oscarl
Wayne, have you ever considered a 1 Pi Tower of 2 cubic feet?
Oscar
Re: 1 Pi Minitower [message #46536 is a reply to message #46534] Tue, 22 March 2005 10:36 Go to previous messageGo to next message
A person could surely make a nice little one π tower. An Alpha 8 in a 2.0ft3 cabinet tuned to 55Hz makes a nice flat response curve with f3 of 50Hz, so that's pretty cool. But it becomes very sensitive to parameter shifts at that size. I think I might make the box just slightly smaller or tune slightly lower so that any shift towards underdamping doesn't result in a large peak. Maybe 1.8ft3 tuned to 55Hz or 2.0ft3 tuned to 55Hz, someting like that.
alpha 8 in 1.35 cu ft [message #46742 is a reply to message #46524] Wed, 20 April 2005 08:35 Go to previous message
Andreas is currently offline  Andreas
Hello Wayne,
i can confirm. I use the alpha 8 in an enclosure with 41 liters (i´m from germany, we don´t use ft, but it is about 1.35 cu ft.)
But i tuned it to 42 Hz. (2ports 10cm/9cm dia/lenght) It sounds great with my fostex fe 103 for the mid-/high-range.
Try it!!
Regards
Andreas
Previous Topic: Really are more than a pretty face
Next Topic: 2 Pi port tuning
Current Time: Fri Nov 20 03:01:14 CST 2026
