Home » Sponsored » Pi Speakers » Corner Horn Recommendations
Re: Corner Horn Recommendations [message #46360 is a reply to message #46356] Fri, 18 February 2005 17:23 Go to previous messageGo to previous message
That's a pretty typical bedroom size, and I know what you mean about needing the space.
As far as acoustics are concerned, what you have is small enough there is pretty good room gain, like what you get in a car. On the down side, the furthest you can place speakers apart is twelve feet, unless you place them in diagonal corners, which I don't like to do. At twelve feet, you have 1/2 wave cancellation between speakers at 50Hz. If you place them a little closer together, say 10 feet, then the 1/2 wave notch is at 56Hz. You have 1/4 wave self-cancellation from an opposing wall back to the speaker at 25Hz, but that's pretty much out of bounds. These are issues you'll have whether the speakers are cornerhorns or not.
Here are some good articles about room placement that you might find useful:
You'll probably have more trouble with aesthetics and size than anything else. The cornerhorns have the benefit of being recessed back into corners and out of the way. They seem to take up very little room space. I suggest making a mockup with a cardboard box to get an idea of size and how they fit in the room. Sometimes it's difficult to visualize speaker size. Cornerhorns always seem to be smaller in the room than they really are, and other large speaker boxes always seem to be bigger than they really are. So maybe mock up a pair and see how they sit in the room.
If you have the room, go with the Audiophile or Professional Series seven π speakers. For a little less money, you might look at the Stage Series seven π or the Theater Series six π speakers. The eight π might be a good choice for you too, because it can be placed in corners or against walls. And if each of these are too large, you might look at tower two π speakers instead.
Previous Topic: 2 Pi adjustments?
Next Topic: Great Plains Audio Club Meeting - March 19
Current Time: Thu Nov 05 20:51:35 CST 2026
