Home » Sponsored » Pi Speakers » 2Pi Towers
Re: 2Pi Towers [message #46173 is a reply to message #46171] Sat, 22 January 2005 18:18 Go to previous messageGo to previous message
Transmission lines use standing waves as their primary tuning method. They usually have a pipe that is 1/4 wavelength of the desired tuning frequency and open at one end. If the pipe isn't opened at the end, then acts differently than pipes that are open at the end. But the designer can take advantage of that as an alternate tuning method, or use a different acoustic device.
Bass-reflex speakers use Helmholtz resonance. However, it is important to realize that both standing waves and Helmholtz resonance are possible at the same time. Standing waves develop inside any chamber, depending on its dimensions and whether it is open on one or both ends or somewhere in between. Helmholtz resonance also sets up in any chamber that has an opening. So the two features aren't mutually exclusive.
Previous Topic: No raw drivers in PI speaker online shop?
Next Topic: New System
Current Time: Sun Nov 22 20:14:08 CST 2026
